How to busyout B-channel on PRI with MGCP on CCM 4.1.3
Answered Question
Aug 16th, 2007
I need to busyout the b-channels on all the T1-PRI's on a WS-SVC-CMM Cat6k voice linecard. I have these configured using MGCP signaling with CCM 4.1.3sr4d
There are active calls on the T1's and I would like to busyout the channels when the call completes.
Any help is greatly appreciated.
Correct Answer by Rob Huffman about 9 years 6 months ago
Hi Anthony,
You can gracefully busy-out (graceful out-of-service) B-channels for troubleshooting purposes. This document discusses how to busy-out B-channels from a Cisco CallManager for Media Gateway Control Protocol (MGCP) controlled T1 or E1 voice ports.
From this excellent doc;
Busy-Out ISDN B-Channels in Cisco CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008076f8d2.shtml
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 08/16/2007 - 07:42
Hi Anthony,
Hope this helps!
Rob
amvita Thu, 08/16/2007 - 11:57
Rob,
Thanks for the excellent information. One additional question...
How can I see if the channel is currently active and when it gets gracefully busied?
This gateway is a Cat6500 CMM blade.
arcaidy76 Fri, 08/17/2007 - 06:37
I don't have in it front of me, but try
show voice call summary
