Switchport dies after host drops and comes back online
Aug 16th, 2007
We are running a 4507R SupII+ switch with WS-X4548-GB host modules. After a host reloads and comes back online, the switchport dies. Attempting to shut/no shut the port, the following message is logged:
Aug 15 15:32:14.164 UTC: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Gi4/25.
This happens on all switchports within this module only. The only way to recover the port is to disable inline power with the power inline never command. I have searched for a bug in this version 12.2(25)EWA4 relating to this and have found nothing.
Should I be suspecting a switch module failure?
I've had a similiar situation but ports were connected to routers. Mine is also 4507R w/ Sup V 10GE with WS-X4548-GB. The only way the ports would come back up was to set the speed to 100.
I came to a conclusion that since CAT-5 cable pin outs are different for 1000 and 10/100 (1000 also uses pins 4578) it couldn't auto negotiate thus the port remained down until I configured the port speed to 100.
This seems like a software bug.
m-sherman Thu, 08/16/2007 - 10:28
John...thanks for the reply.
I did locate a bug that documented a similar issue with 12.2(20) code. Bug ID CSCef87815 but I'm running 12.2(25).....
Pavel Bykov Thu, 08/16/2007 - 10:38
Since it seems like the problem is with autonegotiation, workaround would be to manually set speed and duplex, as suggested.
m-sherman Thu, 08/16/2007 - 10:43
Tried that initially with no resolve. The "inline power never" is the trick.
d-simic Thu, 08/23/2007 - 04:06
Hi, here's what cisco says:
This DDTS is basically a hardware issue that has been resolved by some
rework of the linecards.
Regarding to WS-X4548-GB-RJ45V, linecards with hw rev >= 2.2 are NOT
There is no software fix and affected cards should be replaced.
Can you post a "sh mod" of your switch?
m-sherman Thu, 08/23/2007 - 04:41
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE1043E867
3 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1043E8BK
4 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1048FXA2
6 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1120HP4S
M MAC addresses Hw Fw Sw Status
1 0019.aa4e.f6c0 to 0019.aa4e.f6c1 4.2 12.2(20r)EW1 12.2(25)EWA4 Ok
3 0019.e788.27f0 to 0019.e788.281f 3.1 Ok
4 001a.2f36.e200 to 001a.2f36.e22f 3.1 Ok
6 001b.d400.acb0 to 001b.d400.acdf 3.3 Ok
Mod Redundancy role Redundancy mode Redundancy status
1 Active Supervisor Non redundant Active
Card 4 has the issue
Card 3 seems unaffected
Card 6 is a planned replacement of card 4 which is also unaffected.
