s-doyle Wed, 08/22/2007 - 10:53
There is an XML file for ringtones which needs to be uploaded to tftp server.
Jeremy Ledbetter Wed, 08/22/2007 - 13:25
Custom Ring Tone Install instructions:
- Assumes you already have the ring tones in the correct format and that the ringlist.xml file has been updated for the new ring tones being added.
- Navigate to the CCM OS Platform Administration
- Select Upload to TFTP server
- Upload each .raw, .pcm and the ringlist.xml file to the TFTP folder
- Restart tftp service - CCM Serviceability webpage - feature services - select your TFTP server - restart TFTP service
- restart phone(s)
-Jeremy.
johnroche_2 Mon, 09/24/2007 - 01:57
Done all that, but ringtone does not appear under user prefernces on the phone.
arronf Mon, 09/24/2007 - 22:04
Does anyone know of a way to bulk upload (ie multiple files) at once to CCM 5+?
The reason I ask is that i have a decent number of ringtones that I don't want to manually upload individually through the web interface.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008062b707.html
I've done the above with CME but not with CM, in the process. You may want to check that the XML comes down correctly and is the new file.
