CSM in 6500
Aug 16th, 2007
Can anyone tell me what this command does: persistant rebalance in the following:
vserver 123
virtual xx.xx.xx.xx
serverfarm xxxxxxx
persistent rebalance
inservice
THANKS.
Overall Rating: 5 (1 ratings)
Diego Vargas Thu, 08/16/2007 - 08:25
  • Cisco Employee,
This is the Default behavior for HTTP 1.1; if multiple GETs are present in the same TCP connection, the CSM will examine every GET.
If the new GET needs to be sent to a different serverfarm, the connection with the current server is closed and a new connection with a new server if opened.
This is completely transparent to the client.
Image that you have a serverfarm for people going to www.test.com/development and a different serverfarm for people going to www.test.com/learning
If the client opens a single TCP connection and sends a GET for both sites within the same connection (HTTP persistence), the CSM will match each specific request to its policy and send it to the proper serverfarm (opens a single connection on the backend for each GET).
Hope it helps!!
