CSS interface sending ICMP to PIX
Aug 16th, 2007
I have a css in one armed config. My PIX interface is getting ICMP from the CSS interface, not a service address, but the CSS interface.
The PIX is denying the requests, but I do not see where it is coming from.
They are coming more frequent that the TACACS frequency setting.
I did have some services configured with ICMP keepalives, but they are suspended.
Anyone have any ideas?
Overall Rating: 4.8 (4 ratings)
Diego Vargas Thu, 08/16/2007 - 09:05
  • Cisco Employee,
Hi, the CSS will send a ICMP keepalive by default to its upstream device. In order to disable this, run the command:
CSS(config)# ip no-implicit-service
Hope it helps!!
Gilles Dufour Thu, 08/16/2007 - 09:33
  • Cisco Employee,
just one remark to the info that was given here, the command 'ip no-implicit-service' only applies to newly configured routes.
Once you configured this command, you need to either reboot the CSS or remove and reconfigure the static routes.
Gilles.
Gilles Dufour Thu, 08/16/2007 - 12:00
  • Cisco Employee,
this is au automatic keepalive to detect if the next-hop is available.
If it goes down, the CSS will not use the route and try another one.
Gilles.
wilson_1234_2 Thu, 08/16/2007 - 14:31
Can you set the frequency or number of packets that are sent?
Gilles Dufour Thu, 08/16/2007 - 22:23
  • Cisco Employee,
no, there is no option to configure the automatic keepalive.
All you can do is turn it off.
Gilles.
