basic cabling question
bedevere.curry
I have a as2511 and I want to use it to access the console port on my other devices. I believe I would use a roll-over cable but I don't have one currently that's rj45 to rj45. If possible, could you give me a sample config I would need to setup the line.
thx Cisco
IOS (tm) 2500 Software (C2500-JK8OS-L), Version 12.2(1d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 03-Feb-02 22:01 by srani
Image text-base: 0x0307EEE0, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE
(fc1)
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM
SPECIFIC RELEASE SOFTWARE (fc1)
med_ddevlin
Just an example...
interface Ethernet0
ip address 172.16.1.1 255.255.255.0
ip host Router1 2001 172.16.1.1
ip host Switch1 2002 172.16.1.1
ip host Firewall1 2003 172.16.1.1
etc...
line 1
session-timeout 20
location Router1
exec-timeout 0 0
exec prompt timestamp
no exec
transport input telnet
line 2
session-timeout 20
location Switch1
exec-timeout 0 0
no exec
line 3
session-timeout 20
location Firewall1
exec-timeout 0 0
no exec
For the cable, you just need to make a network cable that has the following pinout:
End1 - End2
white/orange - Brown
Orange - White/Brown
White/Green - Green
Blue - White/Blue
White/Blue - Blue
Green - White/Green
White/Brown - Orange
Brown - White/Orange
Let me know if you need a better example
Please rate if this helps
