Cisco 3845 - Checking Boot Options
Aug 16th, 2007
I am trying to find the command that equals the "show boot" command that I perform on my other devices. Is there such a command on the 3845 Router?
Pete
Pavel Bykov Thu, 08/16/2007 - 10:42
  • Silver, 250 points or more
Yeah, that's odd... can't find it either.
You can use this workaround though:
"show running-config | include boot"
Pavel Bykov Thu, 08/16/2007 - 10:50
I just scanned all of the output of "show tech", and it's not there either.
Command isn't mentioned in troubleshooting guide either:
http://www.cisco.com/en/US/products/ps5855/products_tech_note09186a008073ee69.shtml
Seems it's just not there...
You can find out which image your router booted using "show version | include System", but you probably new that already
