Logging on IOS FW 12.4
emsimon2007
IOS Firewall logging mechanism is only displaying firewalling messages even though all logging is enabled. How do you turn on regular IOS router logging, like login, interface up/down?
royalblues
Level 10
Level 10
What is logging level configured on the device?
Try logging trap debugging
Narayan
Already done this way! :-)
Syslog logging: enabled (1 messages dropped, 6139 messages rate-limited,0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level errors, 3245436 messages logged, xml disabled, filtering disabled
Monitor logging: level debugging, 3698 messages logged, xml disabled, filtering disabled
Buffer logging: level debugging, 227315 messages logged, xml disabled, filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: enabled
Trap logging: level debugging, 3475945 message lines logged
Logging to xxx.xxx.xxx.xxx (udp port 514, audit disabled, authentication disabled, encryption disabled, link up), 3475945 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Can you configure the follwoing command under the interface and check
logging event link-status
Narayan
This configuration is already there...
Would I need to set logging parameters on the interface itself if I wanted to validate traffic passing thru this particular interfaces?
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
