VG200 - Port Adapter Disabled
Aug 16th, 2007
I've got two VG200 gateways that are exactly the same. Same DSP's and everything. I upgraded the IOS on both.
The first one I did it came up just fine, recognized the DSP with no problem. (using the show diag)
The second, I can't get it to see the PVDM. Well, it see's it, but says it's disabled:
Slot 1:
High Density Voice Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAD06000E5N
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 44 30
0x20: 36 33 36 30 45 35 4E 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HDV firmware: Compiled Thu 27-Dec-01 13:17 by miriyala
HDV memory size 524280 heap free 197225
Sorry for what is probably a stupid question, but how do I go about making this gateway enable or bring online this PVDM? When I do a show diag on it, it's just empty... ??
paolo bevilacqua Thu, 08/16/2007 - 11:11
  • Hall of Fame,
    Founding Member
Hello, looks like an anomaly, can you reseat the PVDM or replace with the working one ?
snooter Thu, 08/16/2007 - 11:49
hmm... reseated the PVDM and SIMM's. Still nothing.
I can't try out the other one as it usually has a ton of calls rolling.
Never seen one of these things die before! Although, I didn't start seeing troubles till I upgraded it. The IOS it was running was a 12.1 and there's probably no way of getting another copy of that is there?
snooter Thu, 08/16/2007 - 12:32
Just realized something....
I upgraded to an IOS that the gateway doesn't meet the minimum memory requirements. The IOS still loaded though...would that be causing it probably?
paolo bevilacqua Thu, 08/16/2007 - 12:37
  • Hall of Fame,
    Founding Member
Not sure. You should check the boot process with a console connection to see any error message in there.
snooter Thu, 08/16/2007 - 12:48
Well, I got another IOS within the memory limits, didn't help. Only errors I see on the console startup are:
00:00:05: %HDV-1-NO_DAUGHTER_CARD: HDV in slot 1: no VIC card is inserted in the HDV.
00:00:05: %HDV-3-DISCOVER: HDV in slot 1: the HDV failed to initialize properly
paolo bevilacqua Thu, 08/16/2007 - 12:51
  • Hall of Fame,
    Founding Member
Some hardware problem that the older IOS did not trigger. It happens sometime with when components have "marginal" electrical characteristics.
snooter Thu, 08/16/2007 - 12:54
So, in other words it's probably bad hardware?
