ipv6 eui-64
Aug 16th, 2007
I'm taking the CCIE R&S in november and still unclear on when to use and not use the eui-64 command when configuring ipv6 ip addresses.
I found this statement on the cisco website: "Addresses with a prefix of 2000::/3 (001) through E000::/3 (111) are REQUIRED to have 64-bit interface identifiers in the EUI-64 format..."
but the configuration examples do not use the eui-64 command for ipv6 addresses within this range.
Could someone clarify this?
royalblues Fri, 08/17/2007 - 04:45
Specifying the ipv6 address ipv6-prefix/prefix-length command with the eui-64 keyword configures site-local and global IPv6
addresses with an interface identifier (ID) in the low-order 64 bits of the IPv6 address.
Only the 64-bit network prefix for the address needs to be specified; the last 64 bits are automatically computed
from the interface ID.
Narayan
