Route Patterns to Gateways lose Display Name?
Aug 16th, 2007
Im setting a green field with 2 offices.
Phone 2700 in PT "NYC"
Phone 2700 in PT "SFO"
I added a route pattern "10XXXX" in PT "NYC"
which goes to the SFO Route List.
The call goes through and presents the way I want it to, but i dont get the person calling name. Im calling IP phone to IP phone, going through the gateway.
Since I have overlapping DIDs, this is why I am using Site codes to dial in between and keep 4 digit extensions at each location.
Bad idea or should I move everyone to a 6 digit extension, and use CSS and PTs to dial between sites? (use translation patterns for incoming gateways to translate xxxx to xxxxxx)
I can see it coming through the gateway, but not showing up on the phone.
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Display i = 'Royal Oak'
Calling Party Number i = 0x0181, '202701'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, 'XXX2701'
Plan:Unknown, Type:Unknown
21:37:54.283: ISDN Se0/0/1:23 Q931: RX <- CALL_
Paolo Bevilacqua Thu, 08/16/2007 - 13:56
Where are you sending the call ? If to telco, I don't think they are supposed to carry you calling names? Or, please xpalin how things are connected together.
Tommer Catlin Thu, 08/16/2007 - 14:07
Trying to preserve 4 digit intrasite dialing, and 6 digit intersite dialing.
So when calling 6 digits to a remote site, the Route Pattern sends it to the remote gateway.
Paolo Bevilacqua Thu, 08/16/2007 - 14:11
Sorry, I can't help you with the CCM setting to do this as I do not have expertise in that.
What I do not understand is if intrasite calls are supposed to go over POTS or not.
