outbound caller id on CME 4.1
Answered Question
Aug 16th, 2007
How can I get the full 10-digit originating number to show up during outbound calls? Right now, the dialed number on PSTN side gets the 4-digit extension.
This should be an easy one -- I've done this many times on CCM, 1st on CCME.
Jad
Correct Answer by Paolo Bevilacqua about 9 years 6 months ago
There is more than one way. One is "dialplan-pattern 1 555123.... extension-length 4"
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Thu, 08/16/2007 - 13:54
Paolo Bevilacqua Thu, 08/16/2007 - 14:16
Great. For your information, you're one of the few users in the world allowed to send arbitrary numbers as caller-id. Use that wisely and don't pretend to be someone else, like the White House calling :)
Thanks for the nice rating and good luck!
jelzein Thu, 08/16/2007 - 15:49
Nice to know :)
I ran into another problem - once I added the dialplan, calls stopped forwarding to voicemail after 3 rings...it would just go to busy. Removing it fixed the problem, but now i'm back to square one. How can I get both to play nice together?
Paolo Bevilacqua Fri, 08/17/2007 - 02:57
The thing is likely now, calls going to VM are sent with the full calling number too.
Check debug ccsip message to confirm.
I think something can be done in the VM to accept these numbers as alias of the extension only, if not, there is a simple translation rule you can use instead
voice translation-profile make10
translate calling 10
voice translation-rule 10
rule 1 // /555123/
voice port x/y:23
translation-profile outgoing make10
jelzein Fri, 08/17/2007 - 07:07
Thanks again! That translation rule did the job just fine. I wasn't sure about the VM aliases, so didn't mess with that.
Jad
Paolo Bevilacqua Fri, 08/17/2007 - 08:43
You are very welcome. Now the next part is when your customer will ask that certain extension present DID, others present pilot, and others again present "private" :)
Worry not we'll be here to answer that as well.
