%C4K_IOSMODPORTMAN-4-FANTRAYBAD: Fan tray has failed
Answered Question
Aug 16th, 2007
I have an problem appeared on the Catalyst 4507R switches. I recived the following error message on 2 of the switch consoles but the fan tray was not faulty.
As the message appeared more than one time, and if i understand the error message correctly, the system should be reset but the problem here is the fan tray is working fine.
Temp is also ok.
Can anybody let me know is there any bug in this switch or something else.
Aug 11 11:01:34 10.1.1.157 581084: 587010: Aug 11 11:01:34.426 SGP: %C4K_IOSMODPORTMAN-4-FANTRAYBAD: Fan tray has failed
Aug 11 11:01:35 10.1.1.157 581085: 587011: Aug 11 11:01:34.426 SGP: %C4K_CHASSIS-2-INSUFFICIENTFANSDETECTED: Too few working fans in fan tray, the chassis will overheat. If not resolved, in 5 minutes all line cards will be placed into Reset-Mode
Aug 11 11:01:40 10.1.1.157 581086: 587012: Aug 11 11:01:39.426 SGP: %C4K_IOSMODPORTMAN-6-FANTRAYGOOD: Fan tray is okay
Aug 11 14:27:09 10.1.1.157 582052: 587978: Aug 11 14:27:09.144 SGP: %C4K_IOSMODPORTMAN-4-FANTRAYBAD: Fan tray has failed
Aug 11 14:27:10 10.1.1.157 582053: 587979: Aug 11 14:27:09.144 SGP: %C4K_CHASSIS-2-INSUFFICIENTFANSDETECTED: Too few working fans in fan tray, the chassis will overheat. If not resolved, in 5 minutes all line cards will be placed into Reset-Mode
Aug 11 14:27:15 10.1.1.157 582054: 587980: Aug 11 14:27:14.144 SGP: %C4K_IOSMODPORTMAN-6-FANTRAYGOOD: Fan tray is okay
Correct Answer by sundar.palaniappan about 9 years 5 months ago
Sunil,
Glad to be of help :-)
I'm here in Philadelphia, PA.
-Sundar
Overall Rating: 5 (1 ratings)
