Web Authentication
Aug 16th, 2007
Hello
I have a WLC 4402 and AP 1010s. I have created a guest WLAN. I'm able to authenticate against the WLC. My question is.....How/Is there something that I can configure that when the user opens the browser they get our authentication page?
Thank You
ankbhasi Thu, 08/16/2007 - 23:47
  • Cisco Employee,
Hi Sean,
You can select WEB AUTH TYPE as External(Redirect to external server) and add your web server address.
You have to open the controller gui and then go to security TAB and under security TAB select WEB AUTH link from bottom left hand corner and then from drop down select web auth type as external.
Ankur
*Pls rate all helpfull post
Trending Topics - Security & Network
