How can you monitor a change in redundancy state on CSS
Answered Question
Aug 16th, 2007
Is there an OID in the CSS MIB that would tell you if a box has changed from standby for VRRP to active?
Correct Answer by Gilles Dufour about 9 years 9 months ago
I guess what you want is this :
apIpv4RedundancyVRStateChanges
ApIpv4RedundancyVRConfigEntry ::= SEQUENCE {
apIpv4RedundancyVRIntAddr IpAddress,
apIpv4RedundancyVRID Integer32,
apIpv4RedundancyConfigPriority Integer32,
apIpv4RedundancyAdPriority Integer32,
apIpv4RedundancyName SnmpAdminString,
apIpv4RedundancyVRPreempt INTEGER,
apIpv4RedundancyVRState INTEGER,
apIpv4RedundancyVRMasterIP IpAddress,
apIpv4RedundancyVRLastChange SnmpAdminString,
apIpv4RedundancyVRStateChanges Counter32,
apIpv4RedundancyVRStatus RowStatus,
apIpv4RedundancyVRZeroButton INTEGER,
apIpv4RedundancyVROperState INTEGER,
apIpv4RedundancyVRFailReason INTEGER
Overall Rating: 5 (1 ratings)
dsweeny Wed, 08/22/2007 - 14:25
To display CSS-to-CSS redundancy, use the show redundancy command.
For example:
(config)# show redundancy
When redundancy is not configured, the CSS displays the following status:
Redundancy: Disabled Redundancy Protocol: Not Runninghttp://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.30/configuration/redundancy/guide/Redndncy.html
mmedwid Wed, 08/22/2007 - 23:30
Thanks for the reply. We have a monitoring system that relies on snmp. Is there nothing within the CSS MIB that would indicate a change in state? Thanks.
Correct Answer
Gilles Dufour Thu, 08/23/2007 - 00:47
  • Cisco Employee,
