no sysopt connection permit-pptp but no ACL hits??
Aug 16th, 2007
We have Pix 506E (running 6.3(5)) with Cisco VPN client working fine.
However, I have a question. It is not causing any issue but I need to understand.
We diabled "sysopt connection permit-ipsec" and apply the access-l abc on the inside interface which users establish the VPN connections through.
Somehow this access-l abc has no hits.
Can someone explain why?
access-list abc line 1 permit esp any host (hitcnt=0)
access-list abc line 2 permit udp any host eq isakmp (hitcnt=0)
access-list abc line 3 permit udp any host eq 4500 (hitcnt=0)
pix# sh sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
no sysopt uauth allow-http-cache
no sysopt connection permit-ipsec
no sysopt connection permit-l2tp
no sysopt ipsec pl-compatible
Jon Marshall Fri, 08/17/2007 - 00:35
Because unlike a router with a pix you do not need to specify the IPSEC ports in your acl.
Entering "no sysopt connection permit-ipsec" as you say means that the VPN is subjected to the access-list list on that interface rather than bypasssing it. But that access-list is for traffic once it has been decrypted.
Indeed we had a thread a while back where we tried to stop the pix accepting IPSEC ports on it's outside interface by using deny statements equivalent to your permit statements above and it still accepted VPN connections. Of course without the right key etc. a vpn wasn't formed but the pix still accepted the IPSEC ports.
