srue Fri, 08/17/2007 - 05:36
  • Blue, 1500 points or more
i wrote perl scripts for it - if you want it posted, lemmie know.
srue Fri, 08/17/2007 - 06:34
I am by no means a Perl expert, this is just something i happened to get working. It opens a file at location /path/to/file/pixhosts.db, to get IP's (which i configured a web interface to add/remove hosts for). the format for that is simply one IP address per line. you must first configure each pix/asa with the tftp-server command, and make sure your tftp server is configured properly. then, run the script as a cron job. the script performs a 'write mem and write net'. i wrote a similar script for IOS.
use Net::Telnet::Cisco;
$passwd = 'telnet_passwd';
$enable_passwd = 'enable_password';
open (HOSTS, "/path/to/file/pixhosts.db");
@hosts = ;
chomp (@hosts);
foreach $pix (@hosts)
my $session = Net::Telnet::Cisco->new(Host => $pix, Timeout => 30);
$session->prompt('/[\$%#>] $/');
$session->login('username', $passwd);
$session->enable($enable_passwd);
$session->cmd("write mem\nwrite net\n");
close (HOSTS);
