Attendent Console no active pilot point name in the icon
Aug 17th, 2007
The pilot point icon in Attendant console does not show the pilot point name. The pilot point configuration is properly defined in call manager ver 4.0 and has been associated to the attendant console's user id. Other functions in The attendant console work as normal (control the ipt ext) (call, directory, phone features, active calls) operates like a the key pad at the IPT phone. Did I miss out some configuration?
Auraycats in Singapore
evan.proios Wed, 08/22/2007 - 08:08
I may be having the same problem. console works and I configured all the users and can log in and control the phone and use the directory. When I dial the pilot point I get a busy signal. I can not see the pilot point in the attendent console.
evan.proios Thu, 08/23/2007 - 09:52
Figured it out from the post above. I needed to restart the service.
auraycats Thu, 08/23/2007 - 17:05
Evan, which service you had restarted. Is it CTCD telephony call despatcher?
evan.proios Fri, 08/24/2007 - 05:42
Yes, that service. Now my problem is, which may have been your original problem is I can not see what the PP is doing. I can call it, and q the calls and have it hunt to different users but I can not see on the console scree when the PP is called, how many calls are q'ed on the PP, that kind of stuff. I did assosiate the PP to the users but they can only see the extentions that are on there phone.
auraycats Mon, 08/27/2007 - 00:14
Evan, are you running the same version 4.0 (2A)SR2C like my installation? I could not find this problem reported in tac problem resolving data base. I suspect a bug in version 4.0 or the attendant console is not popular/widely implemented at other call manager sites. At your shop, how many attendant console client? how they find this tool in their daily operation? Is it nice to have or it helps the operator or workgroup to manage the calls in the queue/workgroup.
evan.proios Mon, 08/27/2007 - 05:29
I recently upgraded to 4.2. I am still in testing with the console. I use IPCC call q's right now and the Q helps but users are complaining that they want a gui. The atendent console does not have the expensive licencing like the IPCC does. It looks to me that it will work great but I wnat to be able to see the calls that are ringing on the pilot point, not just the user extention and be able to see the calls taht are in Q. That is what I need to figure out. ZYou can call me if you like 9-5 est 631-852-2000x124
