TCL IVR Problems with media play command
Aug 17th, 2007
I have a tcl Script for an app_debitcard for the IVR application running over a Cisco router 3660 with a billing server that's communicate over the radius
protocol.
The documents that best describes this sort of application is TCL IVR Version 2.0. Programming Guide.pdf from cisco.com.
I am playing the currency and money amount with this command on my IVR :
media play leg_incoming _you_have.au %a$amt %s1000 _enter_dest.au
I need to find a solution to change _dollar.au and _cents.au (which are played by default for this "media play leg_incoming %a$amt" command) into _pesos.au
and _cientos.au !
Can I change this default setting from _dollar.au and _cents.au into _pesos.au and _cientos.au for "media play leg_incoming %a$amt" command ?
How can I do it?
I suppose that infotag must have an option but I haven't found any option for modifing the default _dollars.au and _cents.au...
Thank you and eagerly waiting for your help !
hadbou Thu, 08/23/2007 - 06:13
  • Bronze, 100 points or more
The TCL IVR failure originates from the fact that the interpreter of TCL is ignoring the if control.
if {$amt <= 0}
it instead executes the else command
else { media play leg_incoming _you_have.au %a$amt %s1000 _enter_dest.au } and passes to the translation script a parameter with NEGATIVE value which corresponds to a negative amount of money for translation.
calinbratu Thu, 08/23/2007 - 08:13
Dear Hadbou,
My problem is not this - I need for the IVR to play in colloquial mode the money amount and let me change the _dollar.au file - for playing _pesos.au - whenever I want to ... because I need both types of currency in my script.
In rest the script function well ! No errors...
Thank you,
Waiting for your help,
Calin
