FTP Through a 2800
Aug 17th, 2007
I am wanting to swap a 2600 out with a 2800.
We do application hosting here and one client is behind the said 2600. They do FTP transactions and a few months back when they started this process we fixed the issue by adding the following commands onto the 2600
ip inspect name Ethernet_0_0 ftp
and then
intf 0/0
ip inspect Ethernet_0_0 in
Intf 1/0
I copied the config to the 2800 and made adjustments were the intfa names changed and all works great with the exception of FTP. 2600 is back in place until I can get 2800 working.
Cheers,
Brent Austin
brentaustin Fri, 08/17/2007 - 10:47
Yes, was done to make it as seamless as possible for all clients...
Unfortunately, it does not do the trick.
Is there a way to just allow ftp to and from that is easier than the one used?
Brent
