aim vip
Aug 17th, 2007
Does anybody know if, using an external AIM VIP card the processing power for encryption is added to the internal builtin hardware accelerator in the case of a 3845 router? Is there a posibility to use two AIM VIP cards for the same platform to increase the encryption power?
For provisioning a link with a full 100 Mbps of traffic (both data and voice) how much theoretical encryption power do you recomend? Is the double sufficient?
Thank you in advance,
Gabriel Popescu
thomas.chen Thu, 08/23/2007 - 11:18
  • Silver, 250 points or more
I think the AIM VIP card does adds extra processing power to the router. I donot think adding two VIP cards will increase the encryption power and for 100 Mbps of traffic you may consider some high end router model.
