IPSec VPN problem
Aug 17th, 2007
Hi all
I am having problem in bringing up VPN link between PIX firewall and 3825 router. It was working fine but all of a sudden it stopped. Debug of 3825 is attached for reference. Any work arounds??
Sheeraz
royalblues Sun, 08/19/2007 - 11:58
The error is at phase 1 itself.
Are you sure you have the same properties at both the ends in terms on isakmp policies, encryption, hash, authentication and group?
Narayan
dradhika Sun, 08/19/2007 - 22:24
Hi Sheeraz,
On router can you replace,
crypto isakmp key 6 cisco123 address 203.82.55.106 255.255.255.252
with
crypto isakmp key cisco123 address 203.82.55.106 255.255.255.252
and check.
Also, if you can remove the netmask on both the device in the crypto isakmp key cli if you are establising the tunnel just between these two device.
Cli will to look as below w/o mask-
On router -
on pix -
isakmp key cisco123 address 203.130.2.164
HTH,
Radhika
sheerazkhatri Mon, 08/20/2007 - 05:39
Thank you Radhika for the advise... I did what you suggested but didnt work... Anymore ideas ??
Sheeraz
dradhika Mon, 08/20/2007 - 09:39
have you deleted access-list 104 on router by any chance? or just did not include it in the attachment?
Radhika
sheerazkhatri Tue, 08/21/2007 - 05:17
Sorry for that... ACL 104 is not in the attachement. Following is the ACL 104.
access-list 104 permit ip 10.0.0.0 0.0.255.255 190.190.0.0 0.0.255.255
access-list 104 permit ip 172.16.0.0 0.0.255.255 190.190.0.0 0.0.255.255
access-list 104 permit ip 10.3.1.224 0.0.0.31 190.190.0.0 0.0.255.255
access-list 104 permit ip 10.0.0.0 0.0.255.255 172.16.21.0 0.0.0.255
access-list 104 permit ip 10.3.1.224 0.0.0.31 172.16.21.0 0.0.0.255
access-list 104 permit ip 172.16.0.0 0.0.255.255 172.16.21.0 0.0.0.255
Hope this works.
Sheeraz
dradhika Tue, 08/21/2007 - 09:10
From attached config files.
crypto access list on pix(101) seems to contain different ace's from that on router(104).
Otherwise all the vpn cli seems to be ok.
Can you check the nat is not done for the traffic on both the device.
2.
ip route 190.190.0.0 255.255.0.0 203.82.55.106
here I do not see any interface with ip on this subnet 203.82.55.106.
If 190.190.0.0 is the inside network of pix , then doesn't the next hop ip in this route needs to be 203.130.2.161 instead of 203.82.55.106.
Radhika
dradhika Tue, 08/21/2007 - 09:15
Also if possible , can you disable the ipsec on both the devices and check if you are able to ping the peer ip address and the inside network of the remote device from router (both outside interface and inside interface).
Radhika
