ASA 5510 - Upgrade Path from 7.0(5)
Aug 17th, 2007
Dear All -
I have an ASA 5510 running 7.0(5).
I would like to upgrade to 7.2(2)22 - does anyone know if this is a recognized upgrade path?
I have read here ( that I need to go to 7.1(x) first, but my understanding is that I only need to do that if I upgrade using ASDM as opposed to the command line.
I plan to use the CLI to perform the upgrade.
Thanks, any help much appreciated.
purohit_810 Sat, 08/18/2007 - 19:58
copy tftp disk0:
Same command is standard....
You sent that link it has also command line.
Follow that is standard.. that is no other standard way than that.
Dharmesh Purohit
