purohit_810 Fri, 08/17/2007 - 09:17
  • Silver, 250 points or more
Download Putty
Search on google " Putty ".... using putty telnet.
You can open Hyperterminal and choose TCP/IP option instead of COM1.
Click on OK
You will telnet into device.
Putty use is very good very secure.
Dharmesh Purohit
purohit_810 Fri, 08/17/2007 - 09:23
go into c:\windows\system32
See there telenet.exe... otherswise download telnet.exe and put it on above path.
Dharmesh Purohit
rgruver Fri, 08/17/2007 - 17:35
If you are using Windows Vista Telnet is not installed by default. Go Control Panel, Programs and Features to install it. However, I agree that Putty will work better for you in the long run and give you other features/capabilities as well.
femiayegbusi Mon, 08/20/2007 - 00:33
Thank you so much for your apt response.I will keep you posted.
femiayegbusi Mon, 08/20/2007 - 08:04
I really appreciate your prompt response to my posting.
Cheers....
