Bonding Two T1s with a 3620
jbrunsting
I am attempting to bond a couple of T1s into a single pipe for the network. It's supported by the ISP (SpeakEasy), but they won't support a config on a router they don't provide. As far as I know, this SHOULD be working, but can someone else take a look at this and tell me if I'm doing something wrong? I had to adapt the config from one I knew of on an 1841. Here's the current config:
Current configuration : 2405 bytes
version 12.3
service password-encryption
hostname w2mrouter3620
logging buffered 4096 debugging
enable secret 5 $1$Jlqq$70Q8tQy4jh65n1sPd/X7V1
ip subnet-zero
ip cef
no ip domain lookup
ip name-server 64.81.159.2
ip name-server 216.231.41.2
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
controller T1 0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 0/1
shutdown
framing esf
linecode b8zs
controller T1 0/2
framing esf
linecode b8zs
controller T1 0/3
shutdown
framing sf
linecode ami
policy-map fair
class class-default
fair-queue
interface Multilink1
description 572337
ip address x.x.x.x 255.255.255.252
service-policy output fair
load-interval 30
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink links maximum 4
ppp multilink links minimum 1
ppp multilink group 1
interface Ethernet0/0
description Inside LAN
ip address z.z.z.z 255.255.255.224
ip verify unicast reverse-path
full-duplex
no keepalive
interface Serial0/0:1
description 572336
no ip address
encapsulation frame-relay IETF
load-interval 30
frame-relay lmi-type ansi
interface Serial0/0:1.16 point-to-point
frame-relay interface-dlci 16 ppp Virtual-Template1
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial0/2:1
description 572298
no ip address
load-interval 30
interface Serial0/2:1.16 point-to-point
interface Virtual-Template1
description member link of 572337
ppp multilink
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Multilink1
access-list 10 permit 216.254.0.0 0.0.0.255
access-list 10 deny any
banner login ^CC
Unauthorized access prohibited. Web2Market employees only!
^C
line con 0
password 7 111E4B081443180F54
login
line aux 0
line vty 0 4
access-class 10 in
password 7 044C590B0C705F4D59
login
transport input telnet
ntp server y.y.y.y
end
Any ideas? Thanks.
royalblues
Level 10
Level 10
The config looks fine but can you let me know whether it is necessary to run Frame relay encapsulation on your links
Configs would have been easier with a plain PPP encapsulation
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
Narayan
Well, it's hard to say conclusively. Like I said, I'm just working off of information the ISP gave me, and they listed in a partial sample config running it with frame-relay encapsulation. Is this something I can change on my end without affecting the other? I mean, is it possible to change it to ppp without having to get buy-in from the ISP?
Agree with Narayan, but considering that speakasy, as dynamic and nice ISP they are, is still a second tier ISP, so they are based on frame relay for T1-class customers, hence the need for MLPPP over frame relay.
It should work.
