Multiple Site-to-Site VPNs on a Cisco 831?
Aug 17th, 2007
I have one function site-to-site VPN tunnel on my Cisco 831. I want to add another one using the same external IP address. Is this possible or do I have to start hunting for a second Cisco 831 or a different device which allows multiple site-to-site VPNs on the same interface?
Thanks so much,
Brian
Overall Rating: 5 (1 ratings)
Tshi M Fri, 08/17/2007 - 09:23
  • Silver, 250 points or more
I am not sure but using different sequence number should do the trick.
brianprice Fri, 08/17/2007 - 11:41
I am not familiar with sequencing configurations. Do you have an example which would allow me to virtualize the same interface fro two separate end-client peer addresses? For example, once I configurate the crypto map group and apply it to the interface, I can not apply the second crypto map statement to the interface. It only allows one at a time.
Tshi M Fri, 08/17/2007 - 11:48
crypto ipsec transform-set MYVPNSITES esp-3des esp-md5-hmac
crypto map MYMAP 20 ipsec-isakmp
crypto map MYMAP 20 match address NY-LA
crypto map MYMAP 20 set peer X.X.X.X
crypto map MYMAP 20 set transform-set MYVPNSITES
crypto map MYMAP 30 ipsec-isakmp
crypto map MYMAP 30 match address NY-CHI
crypto map MYMAP 30 set peer Y.Y.Y.Y
crypto map MYMAP 30 set transform-set MYVPNSITES
The trick is to use the same crypto map but with different numbers (i.e. 20, 30, 40, etc)
