VPN to NATed pirvate LAN
I have a pix 506e running on the inside and a single public IP outside. I initially used the VPN wizard to create an IPSec VPN for the cisco client. I can log in and create the tunnel but no inside resources are available. I am even unable to receive icmp echos.
I also tried pptp but the VPN connects the tunnel and then immediately dumps it.
Exacerbating the problem is my PDM manager frequently disconnects from the pix. I am doing this remotely so a clean slate is not an option. the pix is and is the gateway but DHCP comes from a win2k3 AD server.
Tshi M Fri, 08/17/2007 - 09:14
do you mind posting your configuration removing things such as public ip addresses, etc..
Do you have a route for your VPN subnet? i.e. ip route 10.1.1.x or this route might needs to be added in the win2k3 route add -p 10.1.1.x mask I am using 10.1.1.x as the vpn subnet just as an example
