How to show signature definition delta
Aug 17th, 2007
Is there a way to show just the modifications / tuning changes made to a default downloaded signature set?
Background - I've downloaded a signature set, tuned a specific signature-id to a deny event-action, and from what I understand changes are recorded in a sigdef-delta.xml file.
What I'm hoping to be able to do is issue a command that allows us just to identify the detlas in order to avoid a bunch of documentation.
Any help?
attmidsteam Wed, 08/22/2007 - 07:52
If you type 'sh conf' on the CLI on a modern 5.x sensor you will only get the configuration differences (such as different event-actions or different summary keys). The only alternative is to parse out the XML (found on the underlying OS) which is a pain to do (since the XML format isn't completely consistent).
