871: CPUvector 300, PC = 0x811CD7FC, LR = 0x8087
Aug 17th, 2007
Hi all,
(IOS : C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(4)T7, RELEASE SOFTWARE (fc1))
after running the router for month w/o any interruption, the device failed today /few times with an :
Unexpected exception to CPUvector 300, PC = 0x811CD7FC, LR = 0x8087
0BF4
-Traceback= 0x811CD7FC 0x80870BF4 0x80874D90 0x80875794 0x8087593C 0x8034B0EC 0x8034E398
CPU Register Context:
MSR = 0x00009032 CR = 0x88082048 CTR = 0x80870B90 XER = 0x00000000
R0 = 0x00000021 R1 = 0x838C8D88 R2 = 0xFFF4FFF4 R3 = 0x82977218
R4 = 0x8352FF18 R5 = 0x83DBFE20 R6 = 0x00000000 R7 = 0x00000008
R8 = 0x838C8EB4 R9 = 0x83324368 R10 = 0x00000032 R11 = 0x0000000A
R12 = 0x22082048 R13 = 0x87FFFF0C R14 = 0x808757E4 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x827F0000 R25 = 0x827F0000 R26 = 0x82850000 R27 = 0x00000000
R28 = 0x00000003 R29 = 0x8352FF18 R30 = 0x83DBFE20 R31 = 0x82977218
Writing crashinfo to flash:crashinfo_20070817-161819
On the first fail, I reloaded the device and- bang- the flash: wasn't readable anymore !
In ROMMOM I got some strange I/O Errors on flash device. Finally i performed a format flash: successfully and tftpdnld'ed the IOS back to the device.
On first restart, I got again an excpection (same as before) but now the crashfile (I can submit infos from the crashfile - if needed) was written to flash w/o problems and the router is now up and running....
Question:
Is there ANY indicator for a h/w problem ? (I think yes, cause the config was unchanged since july and the router is running non-stop since december or so.)
Will dealer accept an RMA on this issue ?
Is this a (more or less) common problem with 871 ?
Any other out there with this symtom ?
Any indicator in the dump about the cause ? (I have NO experience in analysing cisco dumps)
Best and thanks,
Stephan
Paolo Bevilacqua Fri, 08/17/2007 - 09:14
Hi Stephan,
at first look seems HW related. But please attach crashinfo.
Today was very hot, is your 871 well ventilated ?
stephanhd Fri, 08/17/2007 - 09:50
Hi P. :)
the device is located in germany - but it was hot today too... nevertheless, the device is located in a small datacenter with equal temp all time.
Attached the crashinfo...
THANKS, Stephan
Paolo Bevilacqua Fri, 08/17/2007 - 10:04
Seems like something related to DHCP but, could be erratic HW also. Delete crashinfo and check if it happens again:
flashfs_fsck
tw_timer_start
dhcpc_new_state
dhcpc_process_inpak
dhcpc_queue_event
dhcpc_process
ppc_process_dispatch
process_execute
stephanhd Fri, 08/17/2007 - 10:34
...already done that... fired a bunch of "release dhcp .." renew dhcp..:" and "fsck flash:".... but the device is stable - hmm.
I will try to stress the device a little bit (it's connected to a 10MBit/s uplink) and observe.
BUT:can I still trust the device ?
Best,S.
Paolo Bevilacqua Fri, 08/17/2007 - 12:03
Honestly I wouldn't know.
What I know is if under maintenance contract with cisco, they would replace it no question asked.
