PIX 515 productivity
Aug 17th, 2007
Hi everyone,
The situation is as follows:
My transfer rate is 4-5 times slower if I am behind my firewall comparing to bypassing it.
Memory usage is 30% of total.
CPU usage is in 1-3%.
Is it a normal situation or we just use the wrong equipment and need to implement some more powerfull solution?
rigoberto.cintr... Fri, 08/17/2007 - 09:52
Check to that firewall connections are set to 100Mbps Full Duplex in the switches and the firewall.
dhucaby Fri, 08/17/2007 - 11:49
What PIX software release are you running?
Dave H
anandramapathy Wed, 08/22/2007 - 10:56
The firewall does statesful inspection, It has to check each & every packet, Maintain the state connection, So it would definitely be slower than Direct Communication.
What trasfer are you doing ? If it something like Microsoft file transfer then it is very chatty & the Firewall adds to the Delay.
Try to change the Window size of the TCP connection on both sides ( Usually a registry tweaking on the OS / application helps )
