Can WLC loadbalance users between APs?
Aug 17th, 2007
I am planning for an upgrade to lightweight APs and a WLC. I wonder if a controller can loadbalance users across densely populated APs if the signal strengths are close enough.
If yes, can I manually control it as well?
Thanks!
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Sat, 08/18/2007 - 07:10
  • Red, 2250 points or more
Yes, that is possible, there is a feature called Aggressive load balancing
Aggressive load balancing is an algorith where the APs on the same mobility group talk to
each other to find out what AP is less busy, and when the client wants to associate to an
AP the client will be deny association with a reason 17 code up to 3 times if the controller thinks there?s a better AP in the vicinity for the client.
~JG
Please rate helpful posts
zhenningx Sat, 08/18/2007 - 11:50
  • Bronze, 100 points or more
But many TAC engineers have suggested to disable the aggressive LB feature. They said many cards do not understand it and that just causes more troubles such as disconnecting problem. I am not sure what we should do with this. As TAC suggested, we turned off the aggressive LB feature.
Zhenning
ericgarnel Mon, 08/20/2007 - 05:01
  • Gold, 750 points or more
Interesting. What observations have you made as far as user experiance and/or radio load since you have disabled aggressive load balancing?
zhenningx Wed, 08/22/2007 - 06:47
We also did some other things as TAC suggested(turn off MFP) for disconnecting issue. After those, the complains about disconnecting did decrease.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
