Directory Number issue 5.1
Aug 17th, 2007
having a slight issue with DN that are associated with certain CSS. if for example i have ext 2000 with a CSS of local and i then change the CSS to local_cell i get an error of "update failed could not insert next row - dupicate value in a unique index row". i then do a search and see that there are now 2 same DNs with the different CSS. i have to manually delete the old one for the phone to work.
now we prevously had 5.0(4) and this is still occuring in 5.1(2).
im sure this is not how it is supposed to work.
Note: if i change the route partition everything is fine, its only when i change the CSS.
