cannot access server after chaning its gateway to the ACE BLade
Aug 17th, 2007
When I change my server's default gateway from my router to the ACE Blade, I can no longer acess the server except for on the same lan. I create a route map on the router hoping this would help. but it did not. Here is my route-map info:
access-list 120 permit tcp 10.4.7.6 0.0.0.0 eq telnet 64.78.154.58 0.0.0.0
access-list 120 permit tcp 10.4.7.6 0.0.0.0 eq 8082 64.78.154.58 0.0.0.0
route-map cacheservers permit
match ip address 120
set ip next-hop 64.78.154.7
apply to vlan 11
int vlan 11
ip policy route-map cacheservers
My guess is a symmetric routing.... but How do I resolve this? I know nating will work, but I can't nat do to some requiments to see the real IP's.
Mad__Prof Sat, 08/18/2007 - 20:33
Do you have a route to the gateway on the ACE ?
If possible post a sanitized configuration.
KS
Gilles Dufour Mon, 08/20/2007 - 02:16
is the traffic asymetric ?
like the client going through the router and the server responding through ACE ?
ACE does not like asymtric traffic. So make sure all traffic goes through ACE.
Gilles.
