about C2611XM
Aug 18th, 2007
First, I'm not Bilingual so excuse my English.
Dear Sirs,
Does C2611XM support NM-1FE2W ?
Cisco Ethernet/Token Ring Mixed Media Network Modules
Table 5. 10/100 LAN/WAN combo Network Modules (NM-1FE2W, NM-2FE2W, NM-1FE1R2W, and NM-2W) platforms supported, minimum Cisco IOS? Release, minimum Memory and Maximum Number Supported.
Cisco 2600XM Series 12.2(8)T
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aa71c.html#wp9000230
Best regards,
Overall Rating: 4.5 (2 ratings)
mohammedmahmoud Sat, 08/18/2007 - 01:31
  • Green, 3000 points or more
AFAIK, the 2600 series supports NM-2W only (with no LAN interface).
HTH,
Mohammed Mahmoud.
royalblues Sat, 08/18/2007 - 02:49
As per the Cisco router guide, the NM-1FE2W-V2 card is supported only on the 2691 with IOS 12.2(13)T3
Narayan
mohammedmahmoud Sat, 08/18/2007 - 03:01
I've double checked and Narayan is correct, only the 2691 supports the NM-1FE2W card, while your 2611 will only support NM-2W.
HTH,
Mohammed Mahmoud.
