Configuring a MAC access-list on 2950 switch
Aug 18th, 2007
Hi, I am trying to configure a mac access-list on a cisco 2950 switch running version 12.1(22)EA10a. I have no problem configuring the actual mac access-list itself but when i come to apply it interface fa0/1 for example the 'mac access-group' command is not visible. I have the interface setup as a switchport to access vlan 1. Can anyone advise what im missing here?
Thanks in advance.
flashsplash Sun, 08/19/2007 - 16:36
Hi, untill now i've never seen an access-list created the way u want to do it. But who am i, i haven't much experince yet.
But i think maby you mean the "switchport port-security" command. With this command [and subcommands] u can secure a switchport.
for example:
SW2(config)#int fast 0/5
SW2(config-if)#switchport mode access
SW2(config-if)#switchport port-security
SW2(config-if)#switchport port-security ?
aging Port-security aging commands
mac-address Secure mac address
maximum Max secure addresses
violation Security violation mode
SW2(config-if)#switchport port-security maximum 2
SW2(config-if)#switchport port-security violation protect
this was just 1 example, hope it could help.
bye flash...
CSCO10576352 Mon, 08/20/2007 - 06:48
Hi Flash, thanks for your reply. I am aware that you can use port security to secure a mac address against a port, however this feature does not allow you to configure the same mac address on multiple ports. This is why I was looking into using a 'mac access-list' to control access. As previously stated I have no problem actually configuring the mac-access list, the issue is that when I try to apply it to the interface the 'mac access-group' command is not present.
mrguitar Wed, 07/23/2008 - 11:45
I am running into this issue, as well. Have you found a resolution?
Ed
CSCO10576352 Wed, 07/23/2008 - 22:26
Hi Ed, in the end I gave up and went with 802.1x port based authentication instead which requires the user to enter a username and password to enable the LAN port, the downside to this though is that you require a radius server to do the authentication.
jeanaguemon Tue, 07/29/2008 - 08:49
You don't apply it to the interface; you should apply it to the vlan interface -2950 is a layer 2 switch.
Please let me know if this helps. Thanks.
