08-18-2007 04:49 AM - edited 03-05-2019 05:58 PM
I have 3750G sw & i have connected radio link on port g1/0/20.I want to get access for ping for radio from my local network.
local n/w PC ip-223.***.**.90
mask-255.255.255.0
GW-223.***.**.89
connected on G1/0/19.
radio link- radio IP-192.178.0.20 for my loaction & for customer 192.178.0.21.
customer link is having GW on S/W 203.***.**.55.
Is it possible for me to ping radio's from my PC connected on g1/0/19?
08-18-2007 05:46 AM
Did you create a Layer2 Vlan for the 192.178.0.20 segment and for the 223.x.x.90 segment on this 3750G switch ?
What's the default gateway for 192.178.0.x segment ?
09-01-2007 12:28 AM
No,I haven't create Layer2 Vlan for the 192.178.0.20 segment and for the 223.x.x.90 segment on this 3750G switch.There is no DGy.
for 192.178.0.x segment.But I use add IP add. feature on NIC of PC in which i add IP add.in same network 192.178.0.x .
09-01-2007 06:50 AM
If you want the switch to route between these 2 Vlans;
a) you must create two Layer2 Vlans for each network. In config mode:
Vlan 192
Vlan 223
b) you must assign the Vlans to switchports. For instance:
Vlan 192 -> 192.178.0.x
interface g0/1
switchport mode access
switchport access vlan 192
Vlan 223 -> 223.x.x.x
interface g0/2
switchport access vlan 223
c) enable ip routing on the switch, in config mode:
ip routing
d) create a switch virtual interface for each Vlan and this will be the ip address used as default gateway for each segment.
interface vlan 192
ip address 192.178.0.x 255.255.255.0
interface vlan 223
ip address 223.x.x.x 255.255.255.0
HTH,
09-05-2007 05:15 AM
But in this case Vlan 192 & 223 both will communicate to each other?
09-05-2007 07:59 AM
Yes
