ASA 5510 Site to Site
Aug 18th, 2007
Orginal plan is one uses DYnamic IP and the other uses Statice, but since the dynamic is not working I tried to configure static on both ends but it still will not come up.
Stuck on Pahse 1 - I have used PIX and set them up without any problem.
Here are the configs
REMOTE A
isakmp enable outside
isakmp identity auto
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
access-list outside_cryptomap_20 permit ip 192.168.12.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list outside_cryptomap_20 permit ip 192.168.12.0 255.255.255.0 172.16.0.0 255.255.240.0
crypto ipsec transform-set Site2Site esp-3des esp-sha-hmac
crypto map StaticMap 20 match address outside_cryptomap_20
crypto map StaticMap 20 set peer REMOTEIP
crypto map StaticMap 20 set transform-set Site2Site
crypto map StaticMap 20 set pfs group2 [Tried with and without]
tunnel-group REMOTEIP type ipsec-l2l
tunnel-group REMOTEIP ipsec-attributes
pre-shared-key PRESHARE
crypto map StaticMap interface outside
access-list nonat extended permit ip 192.168.12.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list nonat extended permit ip 192.168.12.0 255.255.255.0 172.16.0.0 255.255.240.0
nat (inside) 0 access-list nonat
REMOTE B
access-list outside_cryptomap_20 permit ip 10.0.3.0 255.255.255.0 192.168.12.0 255.255.255.0
access-list outside_cryptomap_20 permit ip 172.16.0.0 255.255.240.0 192.168.12.0 255.255.255.0
tunnel-group 99.REMOTEIP ipsec-attributes
access-list nonat extended permit ip 10.0.3.0 255.255.255.0 192.168.12.0 255.255.255.0
access-list nonat extended permit ip 172.16.0.0 255.255.240.0 192.168.12.0 255.255.255.0
Double check the config, second eyes is always helpfull?
jason.maynard Sat, 08/18/2007 - 08:17
Here is a part of the debug: REMOTE B
Aug 18 07:18:25 [IKEv1 DEBUG]: IP = REMOTEIP, IKE MM Responder FSM error history (struct &0x351ecd8) , : MM_DONE, EV_ERROR-->MM_WAIT_MSG3, EV_TIMEOUT-->MM_WAIT_MSG3, NullEvent-->MM_SND_MSG2, EV_SND_MSG-->MM_SND_MSG2, EV_START_TMR-->MM_SND_MSG2, EV_RESEND_MSG-->MM_WAIT_MSG3, EV_TIMEOUT-->MM_WAIT_MSG3, NullEvent
Aug 18 07:18:25 [IKEv1 DEBUG]: IP = REMOTEIP, IKE SA MM:1383969c terminating: flags 0x01000002, refcnt 0, tuncnt 0
Aug 18 07:18:25 [IKEv1 DEBUG]: IP = REMOTEIP, sending delete/delete with reason message
Aug 18 07:18:25 [IKEv1]: IP = REMOTEIP, Removing peer from peer table failed, no match!
Aug 18 07:18:25 [IKEv1]: IP = REMOTEIP, Error: Unable to remove PeerTblEntry
Aug 18 07:18:26 [IKEv1 DEBUG]: IP = REMOTEIP, IKE MM Responder FSM error history (struct &0x351f478) , : MM_DONE, EV_ERROR-->MM_WAIT_MSG3, EV_TIMEOUT-->MM_WAIT_MSG3, NullEvent-->MM_SND_MSG2, EV_SND_MSG-->MM_SND_MSG2, EV_START_TMR-->MM_SND_MSG2, EV_RESEND_MSG-->MM_WAIT_MSG3, EV_RESEND_MSG-->MM_WAIT_MSG3, NullEvent
Aug 18 07:18:26 [IKEv1 DEBUG]: IP = REMOTEIP, IKE SA MM:c8b7e093 terminating: flags 0x01000002, refcnt 0, tuncnt 0
Aug 18 07:18:26 [IKEv1 DEBUG]: IP = REMOTEIP, sending delete/delete with reason message
Aug 18 07:18:26 [IKEv1]: IP = REMOTEIP, Removing peer from peer table failed, no match!
Aug 18 07:18:26 [IKEv1]: IP = REMOTEIP, Error: Unable to remove PeerTblEntry
I am starting to think it has to do woth trying XAUTH but ASA does not use isa key .......... noxauth
Tshi M Thu, 09/13/2007 - 04:38
  • Silver, 250 points or more
the problem could be with the encryption you use on the isakmp part. You specified 3des on your transform-set but you are using aes on the isakmp.
you should have
isakmp policy 10 encryption 3des
jason.maynard Fri, 09/14/2007 - 13:58
Actually that is not the issue, the issue was a limitation which only allows 10 inside host to connect. The way around this was to acl the inside interface to permit only essential traffic from specific clients/Servers.
Tshi M Fri, 09/14/2007 - 14:02
interesting...I will think that your encryption would have to match. Well, I learn something new today. Thanks indeed.
jason.maynard Fri, 09/14/2007 - 15:07
There are two phases. Phase 1 was using AES and Phase 2 is using 3DES. As long as both sides of the tunnel match Phase1 in this case AES and Phase2 which is 3DES then the tunnel will come up.
