Protocol not in this image(BGP)
Aug 18th, 2007
When I try to activate the BGP on my router it gives me this message:
"Protocol not in this image."
I have a cisco 1760 router
detail
flash:c1700-ipbase-mz.123-6c.bin
IOS (tm) C1700 Software (C1700-IPBASE-M), Version 12.3(6c), RELEASE SOFTWARE (fc1)
Can you please tell me which IOS Image I have to use in my router.
thanks
Overall Rating: 4 (2 ratings)
mohammedmahmoud Sat, 08/18/2007 - 12:37
  • Green, 3000 points or more
BGP is not supported in all IOS feature sets, you'll need a feature set that supports BGP (for 12.3 starting from SP feature set and your image is IP Base and thats why it doesn't support BGP). Please use Cisco Feature Navigator to find information about your platform and the supported Cisco IOS software image with your required features:
http://www.cisco.com/go/fn
NOTE:
Begining from 12.4(4)T, BGP is supported with advance security feature set
Begining from 12.4(11)T, BGP is supported with even IP base and IP voice feature set.
HTH,
Mohammed Mahmoud.
mshakil Sat, 08/18/2007 - 14:12
Use this image on 1700 router
c1700-k9o3sy7-mz.123-14.T5.bin"
