08-19-2007 02:00 AM - edited 03-05-2019 05:58 PM
Hi NetPros,
anyone who can tell me what does it means ?
%C4K_REDUNDANCY-5-CALENDAR_RATELIMIT: The calendar has been successfully synchronized to the standby supervisor24 times since last calendar syslog
your reply will be highly appreciated.
thanks a lot.
Jackal
Solved! Go to Solution.
08-19-2007 05:37 AM
I think it basically means that the calender clock of the standby supervisor was snchronized rather than being syncnronised from the standby sup.
The calendar maintains its accuracy, even after a power failure or system reboot has occurred. This may be applicable only to the active sup and hence you may be seeing this message when the switch updates the calendar on the standby
Narayan
08-19-2007 05:03 AM
REDUNDANCY-5
Error Message C4K_REDUNDANCY-5-CALENDAR_RATELIMIT: The calendar
[dec] times since last calendar syslog
Explanation The calendar was successfully synchronized to the standby supervisor the specified number of times.
Recommended Action This is an informational message only. No action is required.
Narayan
08-19-2007 05:16 AM
Hi Narayan,
Thanks a lot, but i just curious why the caldender was auto synchronized to the standby supervisor ? if nothing wrong with the sup (Active) ?
regards,
Jackal
08-19-2007 05:37 AM
Narayan
08-19-2007 05:58 AM
Hi Narayan,
Thanks a lot.
Jackal
