CCM PG not coming up
Aug 19th, 2007
I have a small hosted IPCC lab and right now I am trying to configure the CCM PG but I see the following two messages every 30 seconds in the opc window:
13:47:54 Sending initialize PG Agent request - ActiveState=3 Present=1,0 Side=A.
13:48:24 Timeout initializing PG Agent, Activate=3.
Any Idea please? Appreciated.
david.macias Sun, 08/19/2007 - 06:50
  • Blue, 1500 points or more
check that you can ping the ccm from the pg.
dam
halmaktoum Sun, 08/19/2007 - 10:49
I already checked that with ping and tracert as well..
Han
halmaktoum Sun, 08/19/2007 - 10:51
On what port do the PGs and ICM communicate? I might have a problem with port configuration on the ICM box. I noticed that I also have the exact problem with the ISN PG.
halmaktoum Sun, 08/19/2007 - 23:18
Hi Geoff,
No it says IDLE. here is the output of the jtapigw:
16:23:38 Trace: Release 7.0.0.0 , Build 14833
16:23:38 Initializing Node Manager Library.
16:23:38 Trace: Display of EMS messages to the screen has been dynamically disabled.
16:23:40 Trace: Display of EMS messages to the screen has been dynamically disabled.
Han
lpezj Sun, 08/19/2007 - 23:35
  • Gold, 750 points or more
It is important that you active the output trace on the jtapigw process.
Change this registry key and post the output process:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\\PG1A\EMS\CurrentVersion\Library\Processes\jgw1
and chage the 'EMSDisplayToScreen' from 0 to 1.
Hope this helps,
Juan Luis
halmaktoum Mon, 08/20/2007 - 00:52
Hi Juan,
Thanks. I have changed the key and can see the output on the screen now. here is the output:
11:48:41 Trace: Not using CiscoSynchronousObserver interface.
11:48:41 Trace: Initializing JTAPI TraceManager.
11:48:41 Trace: disableAll() TraceManager for CTICLIENT
11:48:41 Trace: Calling getProvider() 100.1.1.20;login=ccmpguser;passwd=<***edited***>
11:48:42 Trace: Returned successfully from getProvider()
11:48:42 Trace: disableAll() TraceManager for CTICLIENT
11:48:42 Trace: Waiting for the provider to be in service
11:48:42 Trace: ProvInServiceEv
11:48:42 Trace: Provider is in service
11:48:42 Trace: Creating Instruments for 2 addresses
11:48:42 Trace: JTapiServer: Wait for adding CallObservers to 2 addresses
11:48:42 Trace: ThreadAddressManager: Adding AddressObservers to 2 addresses
11:48:42 Trace: Call to address.addObserver for 2002 returned successfully after 141 milliseconds
11:48:42 Trace: CiscoAddrOutOfServiceEv Addr: 2002 Cause: NORMAL
11:48:42 Trace: CiscoAddrInServiceEv Addr: 2002 Cause: NORMAL
11:48:42 Trace: CiscoAddrOutOfServiceEv Addr: 2001 Cause: NORMAL
11:48:42 Trace: Call to address.addObserver for 2001 returned successfully after 0 milliseconds
11:48:42 Trace: [Thread-1]ThreadAddressManager ends adding observers after 141 milliseconds
11:48:42 Trace: ThreadAddressManager::processNextQueuedMsg: msgHashtable.size = 0
11:48:42 Trace: ThreadAddressManager::Waiting for next retry
11:48:42 Trace: JTapiServer: Complete waiting for adding CallObservers to 2 addresses
11:48:42 Trace: Successfully configured JTAPI Object.
11:48:42 Trace: Creating server socket on port 40029 to listen for PIM connections.
11:48:42 Trace: CiscoAddrInServiceEv Addr: 2001 Cause: NORMAL
Han
halmaktoum Mon, 08/20/2007 - 04:54
I have attached here a zip file containing outputs of all processes. I hope it could be of any help.
Han
nurulchoudhury Sat, 10/23/2010 - 03:02
Hi Han,
I was also facing the same issue with the same error message. In my case the issue was I have not selected the PG in the DMP while installing the Router.
In your case you can check this from the registry Router -> DMP->Device -> PG enabled or disabled. If disabled then enable it by running Router setup.
Nurul.
