Change ASA5510 inside interface - Internet connection failed
Answered Question
Aug 19th, 2007
Hi forum,
After i change the ASA inside interface IP address, I was unable to connect to internet.
Kindly help.
thanks much,
Correct Answer by purohit_810 about 9 years 10 months ago
If u change IP of ethernet htan you need to change also access list and NAT.
Please see that also carefully.
Dharmesh Purohit
Overall Rating: 5 (1 ratings)
Correct Answer
purohit_810 Sun, 08/19/2007 - 07:39
  • Silver, 250 points or more
Dharmesh Purohit
paulnigel Sun, 08/19/2007 - 16:09
Hi Dharmesh,
Thanks much, that solve my problem!
paul
purohit_810 Sun, 08/19/2007 - 18:31
You always welcome... when you need
Dharmesh
