CME 4.1 Company Logo
Aug 19th, 2007
I have the correct .xml for the company logo as it works fine with CCM4.1. I tried it on my CME4.1 and it will not display the company logo using the url idle command. I have tried using the image with and without the .xml extension in the command.
the image is located in the inetpub.wwwroot path and I can browse to this file from IE. My IIS is also running.
Whst am i doing wrong?
