Test assumptions about ip subnet zero
Aug 19th, 2007
I am getting two stories about whether the current ccna exam assumes ip subnet zero and all 1s subnets are used.
Several of the practice exams I am using to study with operate on the premise that these two subnets are not available unless specifically stated in the question.
On the other hand I am hearing that the current 640-801 exam ALWAYS assumes these two subnets are available.
Can someone clear this up for me? Thanks in advance!
alwahidi22 Sun, 08/19/2007 - 09:20
Hi my friend,
By default if you asked about subnetting you should always know that ip subnet-zero command used , so subnet zero and all ones included unless you informed that ip subnet-zero not used.
By default IOS version 12 and later support ip subnet-zero.
For more information you can check this link:
Ibrahim Alwahidi
