Point to point Bandwidth
Answered Question
Aug 19th, 2007
dear sir
I am using Pont to point microsoft base VPN and using CCME on both side , i wanna know how much bandwidth will be used for 1 voice call from side A to side B with VPN ? and can i register Ip Phone From side A to Side B using CCME ?
I m currenly using 64 K link.
Your assistance will be hihgly appreciatable.
Correct Answer by paolo bevilacqua about 9 years 7 months ago
A regular g.711 call takes almost 90 Kbps plus the VPN overhead.
Your call should work OK on 64 K links if you configure codec g711ulaw under ephone.
If the VPN is passing all the traffic OK, you can register phones across the link without problems.
Overall Rating: 3 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 08/19/2007 - 11:24
  • Hall of Fame,
    Founding Member
