Need to allow inbound connection over TCP 9000
I am trying to configure an ASA5510 (v7.12) to allow an inbound connection over TCP port 9000. I have a web server on the inside that is listening on port 9000 (http://192.168.1.1:9000)
I have setup a static NAT:
static (inside,outside) 1.2.3.4 192.168.1.1 netmask 255.255.255.255
and the access rule:
access-list outside_in extended permit tcp any host 1.2.3.4 eq 9000
Clients on the inside can reach the web server, but those outside the firewall are getting an unable to connect error.
What am I missing? This should be really straighforward.
sureshkum Sun, 08/19/2007 - 23:45
Have u grouped the ACL in outside interface.Have u placed the route?
rajatsetia Mon, 08/20/2007 - 02:44
Check what sureshkum has stated ? also try this ...
access-list outside_in extended permit tcp any host 192.168.1.1 eq 9000
Best thing is to check the logs to get clear picture of your peoblem..
logs will tell you if the problem is realted to NAT or access list.
rgds
purohit_810 Mon, 08/20/2007 - 04:28
Do you have implemented same access-list on OUTSIDE interface?
NAT seems to be fine configured.
Ex:
access-group OUTSIDE_IN in interface outside
Dharmesh Purohit
rigoberto.cintr... Mon, 08/20/2007 - 11:07
Check if you used the correct name in ACL.
Example
Your acl:
Default acl name when you use the ASDM:
access-list outside_access_in extended permit tcp any host 1.2.3.4 eq 9000
