7600 series router or 6500 switch
Answered Question
Aug 19th, 2007
Hello guys,
I was working in one of the solution in which cusotmer suggested 7600 router with sup eng 32.
As the wan feeds were in ethernet , I had suggested 6500 switch to the customer.
Now I need to justify the fact of suggesting 6500 instead of 7600 series router.
pls let me know on what all points we can justify the same.
Your help would be greatly appreciated.
Thanks in advance
Puneet
Correct Answer by jwdoherty about 9 years 6 months ago
I've directly asked Cisco what's the difference between the platforms and initially received "the 6500 is a LAN platform and the 7600 is a WAN platform". But if you press them, they will admit they are pretty much the same box, however they also said they do intend to make them more different, as an example the recent separation in IOS trains. (This seems to agree with much what the other posters have noted.)
As to your question of suggesting a 6500, if everything looks "LAN" like, perhaps it's more suitable than a 7600. If the "WAN Ethernet" connections will need "WAN" features, then the 7600 might be more suitable (not sure there are many vs. 6500, at least today). Besides difference is software features (if any important to you), the biggest issue is likely what line cards you want to place in the chassis.
PS:
Just wondering, since you mentioned sup32, and "WAN Ethernet", are there features needed from the 6500/7600 chassis or might a lesser WAN or LAN platform do the job?
Overall Rating: 4.5 (2 ratings)
thomas.anthony Mon, 08/20/2007 - 01:31
Both has its own advantage and disadvantage, we can justify which device is good only if we understand the client requirement
Paolo Bevilacqua Mon, 08/20/2007 - 01:33
6500 and 7600 are the same product. Cisco has chosen to carry on marketing with two numbers because some customer like to hear switch and some like to hear router. In reality, the box is both things.
Hope this helps,please rate post if it does!
Jon Marshall Mon, 08/20/2007 - 03:10
Hi Puneet
As Paolo said the 2 are very closely related but they are not addressing entirely the same solution. Cisco have started the 12.2SR train for the 7600 router and kept the 12.2SX train for the 6500 chassis. Attached is a link with a bit more information
http://www.cisco.com/en/US/products/hw/routers/ps368/prod_bulletin0900aecd805df25d.html
In essence you need to decide youre exact set of requirements and then choose between them. Generally speaking the chassis is usually one of the cheaper parts of the overall solution with 6500/7600 so your module investment should be protected in the long run whichever way you choose to go.
Jon
puneet_kandwal Mon, 08/20/2007 - 21:56
HI Jon, thanks for your inputs.
Atleast got something to show to the customer.
Puneet.
Correct Answer
jwdoherty Mon, 08/20/2007 - 10:22
PS:
puneet_kandwal Mon, 08/20/2007 - 21:52
Thank you very much for the presise answer.
Just wondering whether 7600 would be more costly then 6500 with the same cards/sup etc.
Thanks again,
Puneet.
jwdoherty Tue, 08/21/2007 - 05:01
I would think they would be comparable in price, but don't hold me to that. If you have a Cisco sales rep or retailer you work with, they should be able to quote some prices.
