rmon alarm creation failure - false OID?
Aug 20th, 2007
Hi there,
I'm working hard to get the problem solved but I'm at a loss.
I try to set up an alarm for over threshold in the rttMonJitterStatsRTTMax so the command is i.e. "rmon alarm 1 rttMonJitterStatsRTTMax 5 abs r 10 1 f 5 2 owner config"
but I receive an "Alarm creation failure".
I also tried instead of MIB object name the OID (1.3.6.1.4.1.9.9.42.1.3.5.1.9).
1.3.6.1.4.1.9.9.42.1.3.5.1.9.
1.3.6.1.4.1.9.9.42.1.3.5.1.9.0
1.3.6.1.4.1.9.9.42.1.3.5.1.9.0.
.1.3.6.1.4.1.9.9.42.1.3.5.1.9
.1.3.6.1.4.1.9.9.42.1.3.5.1.9.0
rttMonJitterStatsEntry.9
etc...
I get either an alarm creation failure or an unknown object message.
http://cisco.com/en/US/tech/tk869/tk769/technologies_white_paper09186a00801b1a1e.shtml#rmonalarmevent
neither works...
Anyone can help?
David Stanford Mon, 08/20/2007 - 05:18
  • Cisco Employee,
You need get the specific index value of rttMonJitterStatsRTTMax like shown in the example:
rttMonJitterStatsRTTMax.100.120518706
Can you walk the object to see what the specific value is? Then you can use this.
kloetpatra Mon, 08/20/2007 - 06:18
Not really. I only know the snmpwalk method in CLI. But is there any other way I can get the value? Especially if you have console access?
