How to configure EtherChannel between 2950(or 6509) and nortel device
Aug 20th, 2007
I would really appreciate if someone can help me on this.
I am trying to figure out whether and how to configure EtherChannel between two 2950 and one Nortel Load Balancer AS2208E, or between two 6509e and One Nortel AS2208E.
Is this possible? If possible, how shall I do it?
/Annie
andrew.burns Mon, 08/20/2007 - 23:17
The diagrams all show an etherchannel spanning multiple switches which isn't currently supported on Cisco kit.
Andrew.
annieliu_se Mon, 08/20/2007 - 23:25
Thank you very much Andrew!
Is there any alternatives I can achieve failover at the switches?
/Annie
