Problem in Wireless Network for Macintosh ichat
Aug 20th, 2007
The scenario is as below.
we have two Apple mac machine which are connected in wired network can ping each other and can use the Software Bonjour ichat through which we can chat locally by creating local user.
But these same machines while connected through wireless could not able to chat through the Bonjour ichat. They are on same Network and can ping each other.
We have Lightweight 1130AG Access Point which in are controlled by the WISM card installed in Layer 3 6509.There is no acl list is applied on layer 3 switch or Layer 2 switch which in blocks the TCP/UDP port 5060 and 16384-16403 ( This are the ports on which the ichat works)
Is there any configuration changes needed to be done on the Controller card. The IOS version of the WISM card is 4.0.217.0
Kindly Provide the assistance.
dsweeny Mon, 08/27/2007 - 06:11
Check if you are able to FTP the files across the conputers.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
