ACS 1113 appliance integration with RSA -Urgent
Answered Question
Aug 20th, 2007
Hi Experts ,
I got the following steps to install patch on ACS 1113 V 4.0 Box.
Instructions on how to install the patch
1. Extract the CSAuth.exe from ACS-4.0.1-RSA-SW-CSCsc12614-CSCsd41866.zip
2. Stop service CSAuth
3. Locate <acs dir>\bin and save a copy of current CSAuth.exe
4. Copy new CSAuth.exe extracted from zip to <acs dir>\bin
5. Start service CSAuth
In step 3, it was mentioned that locate <acs dir>\bin and save a copy of current CSAuth.exe(i.e on ACS 1113 appliance).Could any one help me out the steps to locate the ACS dir on ACS 1113 appliance.
Satish
Correct Answer by Jagdeep Gambhir about 9 years 5 months ago
Satish,
These steps are for acs running on windows. For appliance steps are different. You need patch for appliance.
Attached are the patch upload steps for appliance
You can download the appliance patch from
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Please rate if helps
~JG
Overall Rating: 5 (1 ratings)
smothuku Mon, 08/20/2007 - 06:01
Hi Gambir ,
Thanks a lot for info...
we got sruck at one point .i.e point no 3. Locate acs/dir.
I would like to know how to locate acs dir on ACS 1113 appliance(V4.0) to copy and save current CSAuth.exe before going for patch upgradation..
Please find the attached file ..
Satish
Jagdeep Gambhir Mon, 08/20/2007 - 06:07
Again you are looking at the wrong doc. You have acs appliance and these steps are for if you have acs installed on windows computer.
You need to download the patch for acs appliance from the link I provided.
Once you have the appliance patch, you will apply it as per the doc attached in my last post.
Reagrds
smothuku Mon, 08/20/2007 - 10:56
jgambhir,
Will update once i try on appliance,
Satish
